DIGIWAVE 7000 USALS and AC3
OK…..so as an example, you are on TBN and want to set it for 2 different programs
-JCTV from 1:00-2:00
-Daystar from 2:30-4:00
Program 1
-select channel (JCTV)
-turn on
-YES
-change date & time
Program 2
-select channel (Daystar)
-turn on
-YES
-change date & time
Now it will turn on, change to JCTV at 13:00….stay on until 14:30 when it changes to Daystar. You can set a 3rd to turn off at 16:00 if you want. I’ll take some screenshots on it.
Last weekend I set it to do 2 North Dakota hockey games,…had 4 timers
Timer 1
-Service 1 (that’s what the channel said)
-turn on
-YES
-Nov 4
-19:25
Timer 2
-service 1
-turn off
-YES
-Nov 4
-22:30
Timer 3
-Service 1
-turn on
-YES
-Nov 5
18:55
Timer 4
-service 1
-turn off
-YES
-Nov 5
-22:00
Cool .. as i thought than..
Thanks for your time..
I guess in above example - all of your 4 timers worked no prob? :)
BTW - generally i don't care that much about "turn off" timer.. (even though it is probably good for the receiver to turn off if not used) .. i just let it stay ON .. until i get here :)
But i guess if everything goes OK .. - maybe next time i will try "turn off" timer as well, as the final timer.. - to turn the whole hooray OFF, when it's done :D
Thanks again
yep all 4 went off without a hitch :)
the reason I did the turn off is the channel I was using was a feed and didnt want to see "no signal" for 20 hours :)
Darkman
I set a timer to move satellites, and it still worked :)
Below are some screen shots. I was on Dish 7000 (SD 105 test card) and wanted to program it for UONTV...below is how I set it up
Thanks for those pictures...
I used the Timer feature now couple of times.. (setup a couple of timers .. to change the channel to another channel mostly) .. and this time - they worked OK :)
