Diplex
netdvn
28
America's Historic Triangle
Would some one please explain how to use/configue diplexer to share the same RG6 cable for satellite and cable TV signal? Thanks,
To start, you need 2 of them.
Sat LNB------------\......................................................./---------------------Sat In
............................Diplexer--------shared RG6-------Diplexer
Ant Roof-----------/.......................................................\---------------------Ant In
Sat LNB ------------\......................................................./------------Sat In
............................Diplexer --------shared RG6----------- Diplexer
Ant Roof -----------/.......................................................\------------Ant In
Thanks Lak7. I thought the same way but just want to make sure diplexer can support signal flows either direction. So the bottom line is the L goes to L and H goes to H. Do you have any recommendation on the diplex brand and estimate cost?
Sat LNB (H) ------------\......................................................./------------Sat In (H)
............................Diplexer (S)--------------------------(S) Diplexer
Ant Roof (L) ------------/......................................................\------------Ant In (L)
"So the bottom line is the L goes to L and....."
Where are you getting H, L, & S from?
I just interpreted from your picture and marked some notations :). L stands for low, H is for high and S stands for sharing between H & L. I have not seen a diplexer but they should have some kind of labeling to tell user which one is high and which one is low.
Here's a diplexer on the Sadoun site.
Click the little drawing and see bigger copy of wiring diagram.
Here's a diplexer on the DishStore web site.
Click the photo, for a close-up view, where you can see the wiring info on the part.
But be advised, you don't get something for nothing.
There will be a reduction in both OTA signal and satellite signal.
If you can still work under those circumstances, then a diplexer might be useful.
Thanks Anole,
Mount Pole Support.
Feed question
