Directv D14 live, directv D10 down (update: D10 now working)
NBC Universo HD 410 & TWC Deportes are still down at the moment. I'm unable to get the standard definition version of those channels as I have a slimline 3. Do you think DIRECTV if there unable to get the HD version of those channels back will move the SD versions of those channels off 119 satellite to make it that us with a Slimline 3 are able to receive the channels?
I'd put money on a program error inserted during the many changes they need to reconfigure the system for the new satellites. Even the best screw up once in a while.
NBC Universo HD & TWC Deportes HD are both still down. But it's weird on TWC Deportes HD you can use the Restart feature and you can actually watch the program that should be on from the beginning and it works while the channel currently has a error message up. Weird
An updated post from KyL416 on where things are now.
KyL416 said:
The final list of what's on D14 including the 2 channels in test from D14. (WeTV HD is on D11)
99ca TPN 11 (TID 010):
NUM - NAME - VPID
204 - HLNHD - 1040
232 - COOKHD - 1030
238 - REELZHD - 1060
271 - H2HD - 1020
564 - IFCHD - 1010
694 - FSSDHD - 1050
99ca TPN 13 (TID 012):
NUM - NAME - VPID
275 - QVCHD - 1040
279 - OWNHD - 1010
305 - IONEHD - 1020
404 - GALAHD - 1030
576 - PBTVHD - 1510
99ca TPN 15 (TID 014):
NUM - NAME - VPID
111 - IACHD - 1050
342 - FUSNHD - 1030
557 - *SUNDHD - 1040
611 - SECHD - 1010
677 - LHNHD - 1020
99ca TPN 17 (TID 016):
NUM - NAME - VPID
205 - SMXHD - 1070
274 - OVTVHD - 1030
505 - HBO2wHD - 1010
516 - MAXwHD - 1040
541 - EACTHD - 1020
99ca TPN 19 (TID 018):
NUM - NAME - VPID
264 - BBCAHD - 1060
276 - NGCHD - 1010
285 - IDHD - 1050
286 - DESTHD - 1030
346 - *BBCWNH - 1020
99ca TPN 21 (TID 020):
NUM - NAME - VPID
230 - DIYHD - 1020
266 - FYIHD - 1060
283 - NGWHD - 1050
304 - TVLDHD - 1040
356 - mnbcHD - 1010
654 - FSFLHD - 1030
99ca TPN 23 (TID 022)
NUM - NAME - VPID
256 - TCMHD - 1050
289 - DSJRHD - 1020
333 - MTV2HD - 1040
362 - WEAHD - 1010
674 - RTSWHD - 1030
The info slate has been taken down on the remaining channels, but they're still pointing to the same feed that used to be channel 167 (D11 TID 134 VPID 1020)
Reactions: whitewolf8214
If D10 is indeed back and the issue has been resolved directv will probably be cautious with it, possibly just load it up with PPV HD cinema channels incase it fails again it's less impactful.... Of course I am just spit balling...
Channels still not back
KyL416 said:
The following D10 channels have yet to return:
125 HD Cinema Previews (Offline)
127 HD Cinema (Offline)
129 HD Cinema (Offline)
130 HD Cinema (Offline)
136 HD Cinema (Offline)
145 HD Cinema (Offline)
158 HD Cinema (Offline)
171 HD Cinema (Offline)
353 Bloomberg HD (Slate)
410 NBC Universo HD (Slate)
455 Univision Deportes HD (Slate)
458 TWC Deportes HD (Slate)
9510 103B Odd Test Channel (Offline)
9511 103B Even Test Channel (Offline)
Directv 14 would need to fire up a few more transponders to bring on the rest, but if D10 is online again perhaps it will carry these again.
Notice NONE of these are crucial critical channels ...
Yes everything that was moved off of d10 to d14 appears to be still at d14 according to reports at the other site. I would assume that d10 is up and just running empty at the moment while they test it out to see what works and what doesnt work. This is speculation though. I would figure if the do move anything back it will be well planned and be during the overnight hours. What ever did happen was unexpected and the entire engineering and technical team needs a bigger bonus! 99 percent of the channels restored within 12 hours and minimal impact speaks volumes about the talent directv has!
Direct TV Satellite Dish Installer's Guide
Autopay due date nightmare
Who Read This Thread (Total Members: 7)
