DIRECTV Transponder Map ~ Data 6/18/2025
I overlooked that there are 15 Fast APG PIDs (SCIDs) on TPN 5 for 15 local markets . They are probably not going to convert that TPN to HD. The transponder has been on and off this morning. When up, It has a solid DSS modulated multiplexed digital signal, but there are no audio or video PIDS present. When it is down, there is still a strong DSS QPSK carrier with a SNR of 14.5 dB here in Northern NY. It appears to be fed by random noise. My guess is that they are making changes or repairing equipment in the multiplexors or other equipment in the chain of electronics feeding the uplink transmitter.
I corrected a typo. 15 local markets
DirecTV Satellite Transponder Updates for May 07 2025
Comparison of Transponder Data for May 07 2025 vs Apr 30 2025:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
1 Previously unused Transponder with current APG records::
Net 15 TID 14 Beam NAT is a National Transponder on D12@103ca, TPN 15
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
274​
1447​
SD mpeg4
138​
199​
SD mpeg2
446​
2​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
38​
4​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
A few new TEST channels
Weekly Analysis soon
Enjoy
DataDigesters
Reactions: lordodogg
Prep to move some channels to D12 TPN 15 (MARQHD, FOXDHD, DSTRHD, fuseHD, CBSeHD and TUDNHD)
9755 OFFER - Paramount+ with Showtime is live
Passing along Gracenote's updates for KCBD, KATB, and KZTV
D8 at 119W has another 10 years of life (2035).
The application for renewal of its license is for 5 years, until August 23, 2030. The application states that it will have enough fuel until 2035, but the FCC wants renewals in 5 year increments, according to the application.
DirecTV Satellite Transponder Updates for May 14 2025
Comparison of Transponder Data for May 14 2025 vs May 07 2025:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
275​
1​
1446​
-1​
SD mpeg4
139​
1​
199​
SD mpeg2
442​
-4​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
42​
4​
Some issues with data collection this AM but cleared eventually
Not a lot to post otherwise
Enjoy
DataDigesters
The 900s have been removed
The old 95/119 satellite test channels on 9503/9513/9514 that have been pointing to the Ku Offline slate for the past few years, have finally been removed
9973 *DTV - Commercial Accounts Testing is in test mode
Some more *WNBAION prep (moving them to Ka Offline instead of Ku Offline)
CBSeHD/AHCHD and FOXDHD/TVLDHD swapped transponder slots
Passing along Gracenote's updates for WSFJ and KPIF
Targetted Offers testing:
9751 *APPLE+ (Repurposing CINE 176)
9756 *MOVIES - Ultimate Package Offer
9757 *MOVIES - Ultimate Package Offer
9758 *DTV PP - Protection Plan
9760 *GIFT - TVOD Rental On Us (Repurposing CINE 177)
There's a dispute with with Big Horn Television Group, the actual owner of WMDN/24 Meridian, MS. (Their only other station is the CBS affiliate for the unserved Casper DMA). It's now repurposing Dispute Slide 2 Test 9110
Well IIRC, they've had sports channels in the 900s since 2020, initially because they were running out of room in the 700s due to major tennis and golf tournaments overlapping.
For a short time in the year prior (2019), Comedy Central and BET had their then-newly added west coast feeds on channels 901 and 902, respectively, before eventually moving them to 249-1 and 329-1.
Can't recall them using the 900s for anything else following that USSB merger.
For a short time in the year prior (2019), Comedy Central and BET had their west coast feeds on channels 901 and 902, respectively, before eventually moving them to 249-1 and 329-1.
I remember they used them for local channels.
PIP not showing ON Option
