I haven't heard back from
brittanygarden this week regarding the issue with the H711 software. It is my understanding that she is back in the office as of Tuesday, Sept. 15. I sent her the following information in an attempt to assist with troubleshooting this issue.
If this issue cannot get corrected fairly soon is it possible for me to be let out of my Dish contract? My Dish contract expires at the end of January 2027.
It has gotten to the point where it is past being an annoyance as my wife is constantly letting me know tha the Dish Hopper 3 either doesn't turn on/off via the Sofabaton X2 universal remote (which used to work perfectly for 5 months) or it goes into a 'Standby' mode seemingly randomly while using the OEM Dish remote.
As an example, just this morning the Dish Hopper 3 was completely shut off with the green light off, however it would not respond to any IR commands from my Sofabaton X2 universal remote. I manually pushed the 'Power' button on the front panel of the Dish Hopper 3 to turn it on and then waited 5 seconds or so and manually pushed the 'Power' button again to turn the Dish Hopper 3 off. Both button presses worked as expected.
After doing this the Dish Hopper 3 was now able to respond to IR commands from the Sofabaton X2 universal remote. I ran my 'Startup' sequence via the Sofabaton X2 universal remote which turns on the Dish Hopper 3, LG smart TV and Denon AVR and everything turned on and the inputs were set correctly on the LG TV and the Denon AVR. In short everything worked perfectly.
At this point I let it sit for 5 minutes with everything working perfectly and then I ran the 'Shutdown' sequence via the Sofabaton X2 universal remote and everything shut down as it should. So I ran another 'Startup' sequence using the Sofabaton X2 universal remote and everything worked perfectly again via IR. At this point I began using the OEM Dish remote to change channels, display the channel guide, select other channels for viewing and used the OEM Dish remote as I would for normal viewing.
Here is where the issue manifests itself. At this point the Dish Hopper 3 will not respond to IR commands anymore. When I run any IR command to either start or shutdown the Dish Hopper 3 they are now ignored. This has been the case since firmware version H711 was installed on my Dish Hopper 3. In my amateur opinion somehow using the OEM Dish remote jams up the ability of the Dish Hopper 3 to receive and interpret IR codes.
If it is not possible to get this fixed from Dish's end I would appreciate it if Dish would let me out of the remainder of my contract which is roughly 4 months. I have been a Dish customer for over 8.5 years and my wife and I really like it, but I will not continue to be a subscriber if this doesn't get corrected.
I am available 24/7 for troubleshooting and you or your development team are welcome to contact me directly via cell or email if you need more information.
Thanks.
