Dish Questions
$785.00
smata67
118
OK, I have my coolsat on order. Anyone know a good and cheap source for 90mm or 100mm winegard dishes? Doesn't seem to be a common size. Also, I am interested in a fixed dish arrangement on PSR-1 and Hispasat 1c with a couple of cheap linear lnbs. Can I achieve this with a single dish? I'm trying to get PR channels on PSR-1 and the Spain channels on HSP1c, I can see both from where I want to plant the dish...
I think you mean 90cm & 100cm, as in centimeters; mm is millimeters and that would be tiny. 90cm = 36" and 100cm = 39.3" (aka 1m)
And just because you can see the satellite you still need to check the "BEAM" to see if they are beaming channels you want in this direction. With these weaker KU satellites you may not be able to hit two birds with one dish, that method is usually used with one KU satellite and one (much stronger) DBS satellite to one side.
http://www.dmsiusa.com/charts.htm
Check on the far right, click on BEAM 9 (Lyngsat.com) to see if the footprint makes it to where you are in the country.
Good Luck.
Weekend Project - Pole for the dish!
Source for 1M dish Without the $800 shipping?
