Dish size and EIRP
Mr Tony
3,998
17,325
Mankato, MN
Confused on this goofy EIRP charts for satellites
Where I am located (MN), is a little south of the "46" line but way north of the "48" line….I'm assuming this is why it's a bugger for me to get AMC1 with a 30" dish
I am getting a Strength 58 / Quality 98 with my 1m dish on the Pentagon Channel. It was one of the trickier satellites to set my motor up to as it did require some very fine adjustments.
With Digiwave/Kusat almost anything will give you 98 quality no matter how bad or good you are aiming it so do not be amazed if it requires even more fine adjustments when it's rain.
The Pentagon Channel for me is around 45-60% but took while get it that way.
RtpiFan :)
Iceberg part of your problem getting AMC1 Ku maybe the fact that the polarization on the Ku side is offset about 26 degrees from the other sats. You will need to rotate your LNBF to get the best signal or add another to your dish for AMC1. I added a second LNBF for AMC 1 off of my main LNBF rotated for the proper polarity. I then have both hooked to a disqec switch. Check out the SES Americom website. Look under the Ku payload specs for AMC1 and you will see the polarization offset.
Has that always been like that Scott?
I just got a new LNBF, the Invacom 0.3dB deal. I tried to aim on AMC1 to see if I could get a better signal than my old primestar LNB did, and I locked onto it, and got plenty of quality readings, but when I tried to make it actually view the image with my Twinhan 102g it absolutely refused to start up. Even TSReader would fail to read the PAT or lock the signal, even tho my other apps were saying 'yes there's signal and quality there'. At most I could get 1 frame decoded and displayed but that was it.
I did this before with my primestar LNB and it did actually work to some degree although there was a lot of breakup and crap out which I just assumed was due to the old LNB. but now with my new LNBF I can't get crap out of it.
According to that site that was mentioned I would have to go -26 degrees in terms of the skew on my LNBF, is that right? and again, I raise my initial question, was it always like that?
RtpiFan :)
so true...I have a KUSat and most signals show as 65 signal/98 quality
even if they are only a 50 quality
Pentagon for me is also 45-50 so I guess I'll keep it as is
interesting
so for AMC1 the skew is +26 or -26 from normal?
As far as I know it has been like that since it has been launched. -26 offset is correct. According to my location on a fixed dish my normal skew for that location is about 17 figuring in the offset my skew should be around a -10. I just fine tuned the skew for max quality.
Give it a try when you are on AMC1 sometime. Rotate your LNBF and you should see an improvement in your quality numbers and the amount of feeds you find.
very interesting...have to try that some ngiht this week
Thanks for the tip and welcome :wave :)
i will give this a try with my BUD polarotor tonight. Thanks for the tip.
Do I want a FTA receiver?
Transponders
