Dish View Question
1ADAM12
576
10-6 Gas Pumps
I have utility power and cable wires that my FTA dish will look through. Will this cause problems?
My dishes look through the utility service lines and I have never noticed an issue. High power transmission lines generate a magnetic field around them and have a broader influence on transmissions.
Reactions: comfortably_numb
That's a lot of wires... I suspect there will likely be some attenuation. You'll have to try it out and see if signals are ok or not, it's one of those situations that are dificult to predict and subjective; which wires carry electrical power, voltages/load, cableTV signal (good or leaky cable), etc. Certainly better if you can find a spot where you can avoid the wires.
Prime focus f/D .37 2.4 M dish for Ku Band?
AMIKO HD 265
