DP-301 Receivers & VHF/UHF Antenna
tony2tall
27
With the advent of local channels going digital I will need an Outdoor VHF/UHF.
Presently I have 2- DISH Pro 301 Receivers and watch analog local channel via rabbitt ears but the digital signal isn't strong enough using indoor antenna.
What do I need to combine Sat signal with Outdoor VHF/UHF signal on 1 dedicated coax to each TV?
Need opinion about this Digital Antenna
REMOTE CONTROLLED HDTV HD ANTENNA VHF UHF DIGITAL TV NR - eBay (item 200217406301 end time Apr-23-08 18:29:52 PDT)
I have never saw a rotor controlled via the coax line. Is this good or bad?
Stay away from oddball junk like that, First look at antennawab or tvfool and see how far and what direction you stations are and work from that
Just so you know, the 301 can get your Analog OTA channels because the tuner is NTSC. Next year when all OTA channels go Digital you will not get them with the 301 tuner.
