Feedback greatly appreciated
petewagner33
5
I have a 30 inch dish and a Samsonic receiver that I set up myself. It's been a very trying experience for me, as I have yet to pick up any channels. Here's where I am with things: I have confirmed that my connections and cables are good. I placed a satellite finder in the line and have confirmed that I am getting strong signals from satellites. I have aimed using compass (adjusted to true north) and assumably found Telstar 5 and AMC 3, for which my receiver indicates a signal strength 90-99%, however sometimes poor quality. When I do a channel search after locking on, it indicates 0% or poor strength and I come up with nothing.
Could I possibly have a defective receiver? Are there other satellites right where Telstar and AMC should be that I might be locked on instead?
And finally, is there any receiver or device that could tell me which satellite the signal is coming from?
I'm in NE Maryland.
Pete
Pete -
I moved your post to the MPEG2 / FTA section.
Do a little bit of reading here regarding satellite pointing.
It can be very tricky and require a lot of patience.
I'm in NE Maryland.
Give us your zip and we can give you the angles to vefrify. Is this a fixed dish or a motorized?
I haven’t heard of a Samsonic receiver but it sounds like its working. Remember, signal strength doesn’t mean anything. It’s signal quality that counts. There are 4 KU band satellites between AMC3 (87W) and IA5 (97W)
IA8-89
G11-91
IA6-93
G3-95
What kind of LNB do you have? Is there any info on that? Reason I ask is you have to set it up properly for it to work.
On IA5 there is a LOT of stuff there. I don’t know if the unit has blind scan or not but see if you can manually put in the following info
Freq 12152
Polarity H
Symbol rate 20000
That is a strong transponder and can help you aim the dish.
A SF-95 inline signal meter can help. If using a motor then start by finding your true south sat. If this is a manual move then set the elv of the sat you want and swing the dish around until the SF-95 starts beeping. Send us your zip or one near you and someone might post a list of sats in your area.
petewagner33 said:
Thanks. Is there a tool or receiver that can tell which satellite the signal is coming from?
The receiver won't identify the satellite you're pointed at. The only device I know of that will is a Birddog satellite meter (about $400). But once you peak your signal properly (you probably have to do some adjustments on your dish azimuth and elevation), you can do a blind scan and, by the channels it comes up with, you'll know what bird you're seeing.
