Ok Guys,
Help me out a little here.
I have replaced the 10 foot Winegard with a 7.5 foot Perfect 10 that I refurbished through the winter. Pictures will follow a little later.
I am attempting to tune the 4DTV 920 unit using only the 4DTV. I could take the Pansat up to the roof, hook it up, and fine tune it that way, but I'd rather do it this way.
I have setup a few satellites, and have a few numbers to put out here for comparison.
I started with G1/G15, and have random channels:
channel 160 55Q
channel 115 35Q
channel 165 80Q
channel 103 28Q saw the picture briefly ITC
C4 channel 120 76Q
X4 channel 159 90Q this is the first Ku channel
channel 603 85Q
GB channel 402 47Q
channel 410 71Q
AMC3 Doc Scott TP 20 S90 analog
AMC6 NASA Feed TP5 S90 analog
Haven't been able to hit the test card on AMC2 yet.
Haven't found anything live on SBS6 analog Ku to try it either.
Do these numbers look pretty good so far.
All I have done is put it on the mast, made sure the Elevation Axis angle, declination angle, F/D ratio was set correctly, the Feed-horn pointed smack on into the middle of the dish, and the Focal Distance was set correctly.
My building lies almost straight N/S, so it is pretty easy to sight down the wall of the building and put this dish on 91W. But it may need to be fine tuned a little.
Not getting anything in the way of Ku on the East side kind of worries me a little. I have always gotten the test card on AMC2, but have read the thread where it sometimes is down.
If you have something Ku that I can try East of B6, help me out a little please?
Also, if you can compare the numbers I have and post them, I would appreciate it.
Thanks,
Fred
channel 160 55Q
channel 115 35Q
channel 165 80Q
C4 channel 120 76Q
channel 603 85Q
GB channel 402 47Q
channel 410 71Q
Thanks,
Fred
