froyo for droid leaked
You only have to do those steps the first time to get rooted. outdated, I don't know, as once you get root, you just use rom manager and clockworkrecovery.
Guessing you want to root before the OTA of Froyo hits?
Yes. So do I follow all those steps and then pick an OS?
Ok. I rooted with that app. What is the best kernal/Custom OS to use?
Install Rom Manager, and then you can download it through the software. Splurge and get the premium version.
BTW, the OTA update (non-rooted Froyo) is in the wild. Downloadable from Droid-Life.com.
Loaded it up, works pretty good... though had to do a factory reset to get Marketplace to launch :( The USB tethering IS there but requires the $15 a/mos when you connect.
-Mike
When I tried to install a ROM I got an error. It showed a triangle with an exclamation point in the middle hovering over a phone. Any ideas?
Reflash Clockworkmod from rom manager, and see if that helps. Check out the threads at droidworld too; they should be able to help.
ALSO - maybe do a wipe/delete again.
That worked. I have Pete's Buggless 0.4 now.
I have to redo my home screen though. :(
It reinstalled all my apps to the same version I had which I am happy about, because the new Google Voice took away the ability to use it as a Friends & Family number.
Wow, and I was just guessing. ;)
Actually I have seen similar things enough in the droid forums that I figured it would work; I was just about to suggest you just reboot into recovery and clear the cache again, but you are now bugless. :D
Welcome to the family of rooted love.
Get used to re-doing your home screen; everytime you change a rom, you'll be re-doing your screen.
I just noticed it has 5 Home screens. Nice.
Anyone have Sling that is having problems after going to Pete's Bugless? It says it can't connect to the Sling servers.
Nexus S - the next Google phone
Downgrade from iOS4.2 to iOS4.1
