fss lnb on sso
$735.00
the_man_one
228
how do i get the 13850 setting on the SSO? ran thru the options there is no lof with that designation in the list & i cant manually enter it like my pansat 3500sd.
Are you using a Dish Network stacked FSS LNB from a Superdish? Just use 10750 for your L.O. ... You'll have to abort blind scans once they've finished scanning horizontal (at 50% through the scan) so you won't get duplicate TPs and channels. The vertical TP frequencies will be accurate (but listed as horizontal), and the horizontal TP frequencies will be at 24600 minus the original TP frequency.
Its a bit tricky with the SSO, hopefully someday someone will release a fix-all version of firmware that will finally give this receiver the capabilities it deserves (choice of polarity for scanning, full support for stacked LNBs, fix the clock, fix the high bitrate issues, fix... well lots of fixes) :) ...
i must be spoilt to it... its a great box
Dish elevation angle (again?)
Me-TV died suddenly
