Guide for C2 Online ?
Lone Cloud
701
18
I got my three and have begun my experiments.
I note the angle markx on the back end and the depth measurements on the throat. but I find no guide for installation or tuning online anywhere.
anyone know where to find an installation guide?
There really isnt one....
I know that in most cases the skew is off by 90 degrees and most tuning is trial and error :)
I installed 2 of them today...put at 9:00 skew (like a clock) and went from there
9 'oclock here as well. I just took a small tv and a receiver out to the dish and moved it in and out and around until best signal.
By "9:00 skew" do you mean put the zero ( as in the 30-0-30 scale) at 9:00 ?
yep. For some reason they are off by 90 degrees so put 0 at 9:00 and that should help
Its kinda hard to see but in the below pic I have the dish at 99W which is 6 off my true south. Note the skew on the left LNB
Thanks for the info Iceberg! I just tried to get mine going on a borrowed 1.2M offset dish and couldn't find a signal on any sat. Hopefully that is the reason.
Do I use the scaler and install it all the way to the very end of the LNB? Or do I install it slid down or not use it at all with an offset dish?
I would try as far back into the scaler ring then if that dont work move it in about an inch
I learned with my 1.2m dish it had to be in a inch or so
Thanks man. I'll give it another shot tomorrow!
I want to also try it on my Geosat 90cm and see if I can get anything. Can you recommend the strongest satellite/transponder to try it on?
Available 10' channel master an GI 2750R receiver
My farm is yawn with out my BUD working right
