I plugged the antenna into the H20 OTA slot. How do I scan? There isn't a 'menu' like on E*. Also, how do I enable DD?
You can't scan. You input a primary and a secondary zip for 2 DMAs. It will download and show you what channels you "should" be able to get. Select the ones you can.
When I hit Menu, a little thing pops up and I have to go down to setup and then another large menu pops up. That is what I meant.
Also, whether I crop, pillarbox, stretch, etc, D* stretches my SD channels. If I put my TV on 'Normal' mode, it puts HD channels in 4:3. Do I have to put on Native to keep my SD channels unstretched?
edit: it is actually only ESPN classic on which this happens. I don't wanna see already very bad PQ stretched to look even worse!
I put it on pillarbox and everything works except ESPN classic...odd
I must say I love the PQ. Much better than E*. I don't know if it was because I was on a community dish being stretched over several miles and being used by over 500 people, or if D* is that much better.
The H20s actually can scan for OTAs. I had one for about 2 years. The H20s were the very first of the H model HD receivers for D*. Now the H21s and later and the HR2x DVRs can't scan.
