HD PVR800 FEATURE DVB-S2
If it can do 4:2:2 also (which isnt in the specs or yet to be proven) then that is great. If it can do blind scan but not 4:2:2 its no better than a Pansat 9200
It's cheaper, smaller, and uses less power than a Pansat 9200.
I want PROOF!
Ice,
Would you be surprised that I agree with you on that? :D
Blindscan Menu Screen should definitely be shown, if finalized at that time in firmware. :up
It may not be the case however, which doesn't mean much if its added in a short run. DVB World already said its supported, and the STB Processor and MoBo are powerful enough to handle heavy load fast without overheating. In fact, he said: "Please guys give me the files, I want to fix these features for you as soon as I can since I want SALES, but I don't have these super signals around, and it drives me crazy!" :) Did he say that? ;) He needs signals, samples and...some time to work with them, because without having samples upfront how we can expect these features being already finalized (of course except DVB-S blindscan as you said)? Now, their Linux developers team may be new as well, and needs a bit of time to start playing smoothly. ;)
BTW, it may look premature to start placing orders on this box, we don't know much about from local testers.
Ice,
no not really
but the issue is dvbworld said yes it has blindscan as noted in posts 4 & 6 but yet hasnt shown it. So saying it has blind scan but not showing it gives me doubts
It may not be the case however, which doesn't mean much if its added in a short run. DVB World already said, its supported by the chipset, and the STB Processor and MoBo are powerful enough to handle heavy load without overheating. I tend to trust that since he's a pro, if you know more about him. In fact, he said: "Please guys give me the files, I want to fix these features for you as soon as I can since I want SALES, but I don't have these super signals around, and it makes me crazy!" :) Did he said that? ;) He needs samples and...some time to work with them. ;)
I'm not worried about the PVR...others may be but I'm not. I want it to do blind scan (DVB for sure...DVB-S2 would be a plus) and to do 4:2:2 yet we have not had confirmation that it does either other than him saying "yes it does".
nothing in the specs show blind scan
nothing in the screen shots show blind scan
why would he need a file for 4:2:2? All he has to do is scan in a signal that does 4:2:2 for proof. Scan it in and then give us the parameters so we can see on Lyngsat as example. Unless he is based in North America where we can scan for ourselves as proof we would have to check against something else
BTW, it may look too soon to start taking orders on this box, we don't know much about from local testers.
its pre-ordered. I had a CS8000 preordered before they were available
All I'm saying is I've been screwed (and others have too) by false info on the new receivers. I've purchased too many receivers that claim something and either it is non existant or works like crap. If something is coming down the road, then say it as that. Don't say "yes it does" and make your posts sound like a used car salesman. Heck in post 6 he makes a sales pitch.
Thats all I'm saying.....show me proof and you'll get more sales than a few guinea pigs
Does this box support DVB Subtitling (ETSI 300 743)? Or do you need a sample of that, too?
Ice,
I'm not sure if he has DVB-S2 or 4:2:2 signals in Shenzhen flying around. I just don't know. But I see your point very well. I need fast PVR though. ;)
I checked Lyngsat and there are a couple S2 channels aimed at China...there may not be 4:2:2 there but there is S2 programming on sats aimed at China :)
As soon as Sadoun gets them IN, he can check NBC's 4:2:2's for us at 103w to confirm.
I thought they switched those to 4:2:0 on DVB-S2.
well looks like this box is not all its cracked up to be
From Sadoun himself
I am having the same problem
sadoun said:
As far as this model is concerned:
* No 4:2:2 out of the box
* No hardware Blind Search. Only NIT and Auto Search
* No internal hard-drive included with receiver. You can connect an optional external HD or Flash Memory through USB.
* E-SATA support is not verified yet, but I suspect it is available. I will check on this for you.
see why I was leery? I will be PM'ing or calling Sadoun and cancelling my order. My Coolsat 8000 doesnt have blind scan or 4:2:2 capability yet it has OTA on it :)
An extra e-Sata port may not be required to record a high bit rate TS stream to an HD PVR, since USB 2.0 provides for theoretical 480 Mbits/s transfer rate. What's needed is to select a fast USB 2.0 chipset and fully utilize its supported bandwidth by correct MoBo design, while ensuring the box stable cool operation.
What's the max signal stream bit rate one can currently receive in NA? In what required data transfer & file recording rate it translates? ;)
Well I am glad we have this cleared up. I was really looking forward to this new receiver, but it seems I will have to wait for the features I want to be added to the AZBOX instead.
Sorry for your disappointment Ice.
a new NA box
at least it is a new NA box
maybe the next one will be better
Bummer.. guess I wont be making an order now that the 411 is out.
MIPS architecture - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Ingenic_JZ4730.JPG" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/f/f1/Ingenic_JZ4730.JPG/168px-Ingenic_JZ4730.JPG"@@AMEPARAM@@commons/thumb/f/f1/Ingenic_JZ4730.JPG/168px-Ingenic_JZ4730.JPG "MIPS processors have been commercially successful, now being used in many consumer and industrial applications. MIPS cores can be found in newer Cisco, Linksys and Mikrotik's routerboard routers, cable modems and ADSL modems, smartcards, laser printer engines, set-top boxes, robots, handheld computers, Sony PlayStation 2 and Sony PlayStation Portable.
The low power-consumption and heat characteristics of embedded MIPS implementations, the wide availability of embedded development tools, and knowledge about the architecture means use of MIPS microprocessors in embedded roles is likely to remain common."
DVB World
ALi Corporation doesn't list Blind Scan feature support for its M3501 DVB-S/S2 demodulator. I understand, this info page may be incomplete, but do you have a more complete spec for the demod that lists hadware supported Blind Scan? Or Blind Scan feature in your STB is to be implemented in software? With what search step and signal parameters searched? Any optimization algorithm implemented to speed up the search? How long does it take on average for a typical satellite signals scope receivable in your area?
Sharp Microelectronics website doesn't list the Sharp 7306 DVB-S2 tuner you mentioned. Can you post some more info about this tuner and its specs, or provide a weblink to such info?
Language is an issue. When I visit factories in Asia and talk to development engineers, I have a hard time sometimes getting "our" terminology explained to them. Many think Auto Scan or NIT scan IS Blind Search.
To remind the difference between similar English terms - Blindscan and Autoscan - it may be interesting to look through these threads:
Blind Search / Power Scan - a Sat STB feature that searches (at a fixed step or using a more elaborate step selection algorithm) all frequencies, all symbol rates, all polarities, all FEC's, etc. (within set limits or a series of fixed values for each parameter) for the selected satellite to find all signals emitted by its TPs.
Auto Scan - another more restrictive STB feature that searches only transponders of a selected satellite pre-entered into the Receiver Database using only parameters specified for said TPs in that Database.
The difference between Blind Scan & Auto Scan - US interpretation
The difference between Blind Scan & Auto Scan - UK interpretation
I wish they'd sent Sadoun a sample ahead of the announcement. I ordered as soon as I saw it based on what the company representative said here, but I'll probably cancel unless it can be demonstrated that it does blind-scan.
I'm still waiting to see if dvbworld posts any pictures proving blind-scan or 4:2:2, but his sudden silence isn't a good sign.
1 or 2 fta systems?
AMC 4 101.0W
