Help! with 10 metal mesh dish
sgflats
I recently aquired a 10' mesh orbitron satellite dish with a receiver,
unfortunately, when dismantling the dish, the center metal "star" where all the arms that hold the mesh got broken, ( a few of the metal flanges of the star were broken off, can this be easily replaced?
My advice would be to take the broken parts/pieces to your local machine shop for repair. You may have a hard time finding replacement parts, unless to stumble upon someone that has some old stock.
Depending on how complicated it is, you might get the guy to make you a new one.
Check the price, though.
It could most likely be welded, and for a lot less, if the part is complex.
Even if it's aluminum, there are techniques that could fix it. (MIG or TIG welding)
Of course, if it's broken across screw-holes or parts are missing, that would be a problem.
I had a buddy faced with a $3000 replacement for a busted aluminum engine casing on his motorcycle.
He took it to a local guy who's an expert in such things and got it all fixed up for under $100.
Just takes the right man, with the right tools.
depending on location ..... dishes here are usually cheap , just ask for them ..... so the best option might be search for another big dish.
Winterizing the mesh BUD
Horrible Grinding Noise From my Actuator....
