Hopper with Sling Software Upgraded to S523
$735.00
It's like DISH buying and overseeing the bankruptcy process of Blockbuster never happened..................:lalala
I'm sure they'll write it off as a loss some way. Pretty stupid to spend anything on it and not use it any more than they did. I wonder if they'll stop putting "BLOCKBUSTER" on the right hand side of the Hopper faceplates?
Reactions: MikeD-C05
You have to change it under Guide Settings, Format Guide not under Multi-Swap
Most likely . I see the Blockbuster name being obliterated from any new hopper design going forward.
On S523, did they add the satellite location (back) to the "Info" screen? I noticed it yesterday and don't think I've seen it in a while.
Sent from my HTC6535LVW using Tapatalk
Still at the bottom between the record options and suggested shows/movie titles.
I thought it was too, then it disappeared for a short time, and is back now (?).
Also, I noticed one or two (I did not check more for this purpose) program details that were 2-4 lines long and ended with "...". I thought they increased the text "field" for this a while ago and descriptions weren't being cut off. If I remember, I'll check more later.
The orbital location has been there all along. It only displays when you're watching live TV. It doesn't show when you're watching delayed or recorded programming.
Reactions: Hall
I thought that might 'xplain it'. :)
Since S523, I've now had three instances of the "jump to end" bug while using the 30 second skip button during a recording. When it happens, only the stop button works which means I have to start the recording over and fast forward to where the bug occurred in the recording. Never had this until 523.
You can click the page down button( right below the aux button) to see the remaining text.
You shouldn't have to though and it's not intuitive that you would. There is blank space for multiple more lines but they're not using it - as if it's reserved for something else.
I thought it was before that. something like 512 or 514
Might come back to satellite
TVs with Dish Joeys go black and lose audio
