How to do a hard reboot?
$0.00
$400.00
NybobbyNy
10
I may be having a problem with my OTA Module. I was told to reinsert it and than do a hard reboot? Is a hard reboot simply leaving the unit unplugged for a while, or is there some other way?
Thanks again
You should unplug it when reinserting the OTA module, anyway, so there should be no need for additional reboot really. ;)
What kind of problem are you having?
Thanks for your replies.
The problem I am having is after I gained access to the "Install Wizard" and try to scan for locals the whole screen just blinks while it scans. This will keep on happening until I press back. I also tried to "Aim Antenna", but that blinks too. I tried reinserting the OTA, but that did not help. I currently dont have an OTA antenna hooked up because my landlord is giving me grief about putting one on the roof.
Secure Firmware:V16
Current Software 02.4C
HAL Version: 00.07.37
Middleware Version: 01.45.02
Sounds like a hardware problem. Perhaps a bad OTA module.
What happens if you manually tune to an OTA channel?
Hi, Ilya. Thanks for the reply. I am not sure how to manually tune in. I just tried tuning in thru the Install Wizard, but I just tried another OTA module that I know works and I had the same blinking issue
Of a top of my head: in the Installation wizard menu there is a scan option and there is "Tune OTA antenna", or something like that. Try both options.
FAYRICH said:
You say that you don't have an OTA antenna hooked up. You cannot receive OTA stations without one you know.
I bought 2 Vooms receivers. One works fine, the other is the one I am having the blinking issue with. I assumed it was the OTA module, but when I swapped it with the one that I know works I still had the issue, So I never hooked my indoor antenna up to the "defective" one. I was hoping I could figure out what is wrong with it.
I tried several indoor antennas, but I cant get more than a couple of stations (Fox, ABC) even though I am only 9 miles from the towers. My landlord wont let me put a Winguard on the roof.
I was wondering if anyone could comment on THIS antenna
NybobbyNy said:
I bought 2 Vooms receivers. One works fine, the other is the one I am having the blinking issue with. THIS antenna
Had both receivers been activated?
Locals in HD by cable
voom box schematics
