will probably do some tweaking tonite. Right now a couple TP's are lower than I want them to be but all are stable enough (45 on nets, 33 on KCWY, 60 on My Net and of course 89 on WHT...crazy religious channels and their strong signal)
It's been said before - at moderate wind speeds, a mesh dish receives similar wind loading to that of a solid dish. This is because the mesh causes wind turbulence that creates wind resistance similar to a solid dish. At low wind speeds, the turbulence has a lesser affect, but the affect heightens as wind speed increases, until there is not effective difference in performance against wind.How about this:
...Assume that a mesh dish has a 50% open area, then only 630 pounds are required to keep it upright.
That's always been the advantage of a mesh dish, lower wind loads.
Lowes, Home Depot, and some well stocked hardware/building supply stores carry various sizes of aluminum and steel square tubing. Measure or take a damaged piece with you and see if it can be matched in size and material.
Harold
.....replace any damaged panels as well....
Yea I'd like to know the same thing. I have a 180cm "stationary" and would like to make it into a "polar mount" but I need the modified circular ring on the back. I was told awhile back they (Sadoun's) couldn't get replacement parts and I would have to buy a whole new dishSadoun:
Does this mean you're able to get replacement parts now? My earlier post saying replacement panels weren't available was based on an email to your Customer Service Department about a month ago. At that time, I was told that replacement parts weren't available.
Thanks,
Harold
....I was told awhile back....
......replacement parts......
Leave it to a SatGuy to even know such a fact!Have had sustained (1 minute average) of 65 mph with one gust of 111.8 mph.
