IA8 signal?
Mr Tony
3,378
14,852
Mankato, MN
Just out of curiousity, what kind of signal is everyone getting with IA8?
When it first came up, I had a 75 signal. Now the best I can get on the test card is a stable 35. I don't want to tweak the dish because everythign else is good signal (and IA8 was fine originally)
Using a Pansat 1500, 30" and .3
What are the Pansat users getting? :)
IA8 on a Pansat 3500s with an 80cm and .6LNB I get 15-30% quality. I either have a bad dish, or LNB, no matter how much I try to tweak the dish I never go above 30 and it bounces. This is my true south bird as well.
ACD
I have a 76cm and a .3 and get 30-32 all the time so maybe they arent running at full power :(
The best I've seen on the GC mux with my 80 cm dish and 0.3 Invacom on my FS Lifetime Ultra was a 49% quality. It could probably be aligned much better, though.
I have a 90 CM dish, and I just moved my dish to the roof and I will give you the big report how it's goes! :eek:
Right now I am Dxing the Echostar 6,8 bird and the signal is pinning my meter at 99% too hot!!
I plan on working on my way down to G-10 and maybe just west of that satellite.
Hey Ice,
That happened to me, so I changed my sats (IA 8) position from 89 to 88.6 degrees and the signal strength went back like it was. I have it set with USALS. I believe the sat has moved (drifted or whatever) a bit to the east.
Al
My new LNB arrived, the QPH-031. Since IA8 is my Due south, I should have an answer to the signal on this one tonight.
Dang, I got it all hooked up and was busy mussing with it, and watched a few new channels and forgot to look! I was able to pull in a few new TP's though. I think I was getting around 60% on it, but I need to update the firmware for the signal fix.
What is strongest TP on IA8?
I have being trying to find it without much sucess i can get G3C fine IA8 more to east nudging motor slowly should get me their eventualy but not so far.
Tony :)
crap. there is a feed for the hurricane stuff...thats pretty strong but I dont know it off the top of my head
Otherwise the IA8 test card (that can be found at Lyngsat)
Pansat 3500S Setup.Help!
no signal strength
