inner switch on lnb
$835.00
caretaker
35
richer mb. canada
has anyone opened a bsc621 mine is not switchen to ku side & after trying all things leads me to think switch inside not worken even if i connect directly to ku side my sat finder shows no signal but lite is on so fta sending power to switch. that or ku lnb shot :eek:
Have you used this 621 before and had it function, or is this your first try with it?
Is it new or used?
There are two models of BSC-621.
The one with a Standard Ku LNB, has a 22khz switch.
And the other model with a Universal Ku LNB, has a diseqc switch. (BSC-621-2?)
(That's from memory, so check their web site to confirm)
edit:
Okay, this .PDF compares the two models.
And read about the focal point, to properly tune the beast.
yea was worken then was watchen tv when quality dropped then to 0 q strength signal str. stayed @ 73 cband side still works good. its the standard 621 not 621-2 took ku lnb off seems ok still think its the 22 khz switch. its a sealed unit no screws. is there a way to check it without prying it open
You can use an external switch as a replacement.
The Standard BSC621 (L.O. 10750) uses a 22KHz switch.
If you power down and connect directly to the Ku LNB at the tip of the BSC, do you get good Signal and Quality?
Which direction do I go?
no audio with HDD 200
