iOS, MacOS, etc. 26 is making me seriously consider switching
$585.00
Today's annoyance: Apple Fitness simultaneously thinks I have 857 active calories and 81 exercise minutes while showing Saturday (up top) as being a very light day.
  • Wow
Reactions: Foxbat
I've not seen that, but I usually don't use the Fitness+ app on my iPhone. Try sliding the rings to the left and see what it does.
Yeah, I played around with it, restarted the app, etc. It is showing me a mix of data from the current and previous days. I've had an Apple watch for 10 years, and it never worked like this before the latest iOS update.
Reactions: Foxbat
If it wasn't clear, I regret upgrading. I recommend everyone who can wait until they fix the problems or come out with something better.
The problem with waiting is apparently the previous generation of iDeviceOS has an exploitable vulnerability that can compromise your iDevice security. I don't know if it's something that Apple can fix, which bums me out with family members with vision issues which would make "Liquid Glass" impossible to use.
I've not tried but I thought it was possible to turn off the Liquid Glass feature?
I haven't tried it yet. I need to be sure on their iPad as there's no going back. Also, the windowing in iPadOS needs to be shut down to prevent any possible confusion. That's fairly easy to do.
I turned the windowing thing off as well. I found it mostly irritating.
Reactions: Foxbat
I guess I don't feel obligated to have the latest and greatest. I updated my Mac in 2015. The OS and Office stopped getting upgrades years ago, but it keeps on doing most everything I need it for. Last year, TurboTax stopped supporting/ working on Monterrey, so I changed tax programs.
I suppose atsome point I may need to change, but I may just go pure android tablet at that point. I do most work on one anyway and simply can't justify Apple's prices for my simple needs.
Is Apple now adopting the Microsoft stance that previous versions of its OS don't need to be actively maintained? This is especially inexcusable given an annual release cycle.
This is also important in an environment where there's obvious push-back against changes that are perceived as undesirable or unfinished (i.e., Apple Intelligence that arguably isn't yet what they touted in the previous version).
I didn't write it, so I don't know what the vulnerability is or why it can't be patched. Apple is insisting on moving to OS 26 for safety. I agree, if it can be patched to remove the exploit, they should be required to support old OS versions for a minimum of three years.
So, you have a Macintosh that you've been able to use for eleven years. I think you've gotten your money's worth out of your investment.
I found I was experiencing iCloud synch issues because my 2014 iMac couldn't go past one of the California landmarks. So, I got the Mac Mini with M4 Pro in 2024 and I'm ready for another ten years. I probably would have had to get three PCs in the same timeframe. But now I just need to replace the Mini, not the screen and CPU in the iMac.
I agree, and the mini is probably a good idea. It would make a ton of sense if I was still working and needed serious firepower. But I am in my late 70s and retired. I browse the net, use word and excel, occasionally use a videoconferencing app and do taxes. As long as those still work, I have no need to upgrade. When I do, I will look into beefing up the tablet instead.
Reactions: osu1991
Apple typically releases security patches for the current and 1 previous version of their OSes, so 26 and 18 in the case of the iPhone. As of right now, Apple has patched all critical vulnerabilities in iOS 18 based on the security dashboard I can see at work. Sometimes they will patch vulnerabilities in even older versions if they are still widely used, but it is rare. Officially, Apple has not policy, but that is what they do in practice.
You can make Liquid Glass slightly more readable through a couple of methods, but there is no way to completely avoid a lot of the transparency look and feel that break actual functionality. For instance, in Apple Music on MacOS 26, I recently discovered I cannot select artists that are near the bottom of the window when in list of artists. If I scroll up a bit, clicks register, but not near the bottom.
If, as is often the case, the problem is with Webkit, what, outside of being punitive, prevents that fix from being applied to many versions?
Probably just the fact that no team at Apple is responsible for older versions of OSes that include vulnerable versions of WebKit. That said, Safari does tend to be one of the few things they will patch beyond 2-3 years...occasionally.
OK, Apple Music. Why does it make sense to group Mike + The Mechanics with Genesis? Yes, there was a member of Genesis in the band, but that doesn't mean Genesis == Mike + The Mechanics.
You answered your own question. The music streaming services have been including "you might also like" artists for a while now.
MyGica Pad TV Tuner
