little help
jappleboy
312
I have a Directv HD Receiver hooked up to a HD tv set. Now this is were i need some help. It is an older HD set so it is DVI Hook up now can i run a video out with audio out at the same time. I do understand if both tv are on at the same thime you will have to watch the same show.:confused:
I am not sure I understand what you are asking. Are you simply wanting to hook up audio with your DVI output? Or are you trying to hook up two TVs with the same box?
You need a HDMI -> DVI adapter/cable, see Video Cable - <b>HDMI/DVI</b> for cables. Then use the audio outs on the HD receiver and connect to your TV using whatever audio input goes with that DVI input.
No RF setup
Directv with TiVO
