Locals Transponder
tnank
7
Is there a web site where I can find out which transponder my Wilkes-Barre Scranton Pa. sd locals use. I lose the signal on the locals on occasion but the main channels are ok. Thanks
Is there a web site where I can find out which transponder my Wilkes-Barre Scranton Pa. locals use. I lose the signal on the locals on occasion but the main channels are ok. Thanks
I asked the same thing a few months ago. I was losing signal from Bham. The reply was that no one knows of a transponder list for locals by Direct.
Not sure, but if you check the signal strengths on the spot beam sats (99s and 103s), the TPs with the higher numbers most likely are the TPs for your area.
HR 21 won't play recorded show
slimline install question
