I had a DirecTV setup with 2 Zinwell 6x8s, Slimline 3 dish, and all was well.  We have multiple dual input DVRs so I needed 10+ lines.
Recently we lost our 103 signal and I noticed our dish pole had come lose, so I put in a new pole, and re-aimed the dish. Also put in all new cables (4) from the dish, as I discovered 1 of the cables had gone bad (no signal coming in from that cable). Replaced the LNB on the dish just to be sure as well. Now direct to a receiver I get all satellites and very strong signals.
However if I go through the Zinwell 6x8, I am losing the 103 sat signal to all TVs. I have two Zinwell 6x8s that were connected before -- I have tried both individually and get the same result -- 0 signal on 103. 99 and 101 work fine.
We did have some storm activity before the trouble started -- is it possible that both Zinwell's got fried? Perhaps the bad cable was the one that went into both Zinwells on the 103 input, and that input got fried on both?
I am assuming at this point I need to order some new Zinwell 6x8s, or a Zinwell 6x16 if I can find one.
Would you concur with my analysis?
Thanks much for any input or advice!!
