Manual IP/Gateway/DNS Settings?
traustic
17
Texas
I have an old wireless bridge that works if all clients connected have manual network settings enabled. Nothing is grabbed from the dhcp server off the primary router/modem from any client that is connected to this unit. Is there a setting I'm missing on my wireless bridge or my modem? Is there a place I can set the network info manually on a joey?
Wireless Bridge:
Buffalo Turbo G Air-Station wli-tx4-g54hp
DSL Router Modem:
D-Link DSL-2750B Board
Looks like it is time for a new bridge or setup you bridge as a DHCP pass-thru
Nope, not that I'm aware of. Did you enable DHCP mode on this access point? Because that's going to need to be enabled since there's a fair amount of consumer equipment out there that doesn't let you set the IP address.
Dish QAM setting
Problem with Dish Anywhere
