GEOSATpro microHD Hard Drive Compatibility Thread
Tron
6,599
35
Metro New Orleans, LA
The WD Elements drives seem to be an excellent choice for many devices such as the microHD, since these drives don't have special capabilities such as capacity displays and odd partitions that cause problems with receivers, media players, etc.
chaskuchar
807
14
saint charles, missouri
got my drive to replace the wd300g that was doing the job nicely but i need it in other places. this one appears to be working ok. seagate staa1000101. a 1t drive that is usb3.0. charlie
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,054
7,369
EM75xb
Can the Micro Access and use the whole Terabyte, I don't see why not.
KE4EST
Staff member
HERE TO HELP YOU!
27,054
7,369
EM75xb
That is what I was thinking, but wanted to be sure....thinking about ordering a Terabyte drive too.
Cham
VE4GLS
2,566
1,142
Boonies
Just picked up a really cheap external 2TB HDD unit but not having any luck getting the Micro to "see" it. It's a Western Digital My Book with a USB-2 interface, formatted to NTFS. Model # is WDBAAF0020HBK-NESN. I suspect it may require a driver to run as it seems to be pre-loaded with backup software of some sort. Has anyone tried one of these before?
Might hook it up to one of the windoze PCs and see what it does there... Maybe it can be re-formatted or partitioned somehow to make it work...
-C.
SatelliteAV
6,486
186
Roseville, CA
-C.
Google search shows many complaints related to the automatic backup SmartWare installed on this drive. You might try visiting the WD website and learn about disabling the function. In my experience, DVRs require bare drives.
Cham
VE4GLS
2,566
1,142
Boonies
Happy New Year Brian!
Yes I agree best to start from scratch with a freshly formatted drive. Think I'll have to find a different HDD now the Wife is using it on her PC and has files on it now. Oh well... Back to the drawing board I guess... :)
Cham
VE4GLS
2,566
1,142
Boonies
Just an update, I managed to get hold of the drive again so I downloaded a small file from WD to disable the Virtual CD function on the drive and now it works fine. Re-formatted the drive after the micro recognized it. Tried recording and works great on the mpeg4 PBS channels so I suspect it will work on the others as well.
KE4EST
Staff member
HERE TO HELP YOU!
27,054
7,369
EM75xb
Just bought a Seagate 1TB GOFLEX DESK. Good Price, and so far is working great on the micro..:)
wfarqwark
Sep 23, 2012
5
United States
Dumb question time....what format is the Micro hd recording in .TS etc.....I'm thinking of burning a dvd of something I put on my usb drive
A little late -- I find VLC will play a .ts file great. I am using linux but think there is a version of VLC for Win. Also try renaming it to xxxxx.avi and see if you windows program will play it.
northgeorgia
1,557
211
North GA
I use a Western Digital Elements 1 TB external drive, retired from my home computer. At first it worked well, then I started having problems accessing the drive at about 35% capacity. What has to be done, and this is a bit of an aggravation but necessary if you want flawless performance, is to connect your drive in question to your computer, and do a FULL format (not quick format). This will reset the drive completely (I've had no problems since...already up to 70% capacity of just junk recordings). I say it's aggravating just because of the time involved. If I remember correctly, the full format of a 1 TB drive took around 14 hours to complete. Well-worth it, but just realize it will take some time to format the drive if you have one of a significant size.
Mike045
103
8
Quebec
Is the Western Digital MyPassport Ultra USB3.0 2 To (model WDBMWV0020BBK) comptatible with the GeoSatPro MicroHD ? I had before a USB2.0 HDD with external power which worked well, but not sure for the self-powered USB3.0; any help would be appreciated.
Happy New Year to all (yes I know, a bit late)
Mike
AMIKO Amiko mini HD Se.How add a new satellite?
AMIKO Sling TV on A3
