My motorized Primestar is on a tripod, and thus can only be on the flat part of my roof from where I can only see 93W - 129W. The slanted part of my roof has a place that can see as far east as 77W if not more, but there's no easy way to mount another decent-sized dish there and I don't have another good dish anyway. I just happened to have a spare 6-block non-penetrating mount, a Sadoun DG240 motor, and a Dish 500 laying about, so I decided to put them to good use. I'd say more, but I'll just let the pictures do most of the talking. No booze was involved in this project, I swear!
The skew adjustment plate in the back of the dish was running into the motor shaft when I tried to raise the dish to the necessary elevation setting, so I had to cut a notch out of it with a Dremel.
119W is about half a degree off my true south and the LNB isn't at boresight, so I did some calculations and turned the motor shaft a few degrees to compensate. I realigned the motor with the compass, hooked up the 110W LNB, peaked the signal, turned on the receiver, and suddenly found myself watching TV on the roof!
Once I'm sure that this thing is tracking the arc properly, I'm going to put a linear LNB on there and see what I can get. If nothing else, I'm getting one more channel than before, so I'm declaring this project a success
Edit: In case anyone is curious, that channel is NBA TV which is currently in the clear at 110W (MPEG-2) and 72.5W (MPEG-4).
