Mounting Location?
Kevin1514
38
Seattle
I am planning on ordering DirecTV service for my grandparents and need some help with how the dish should be mounted. They are just getting 2 standard SD receivers and they still install the single lnb dishes in my area.
My problem is my grandparents have vinyl siding and they don't want holes drilled in the siding. They also would prefer not to have holes drilled in their roof and last winter a storm partially blew off their roof. I had looked at putting the dish in the fascia board but from reading posts it seems that is a bad idea, or is it really that bad?
If they were to use a pole mount how much extra does directv charge to do that and how do they run it to the house? Do I need to dig a trench for the cable? Thanks for any help.
The fascia should work for mounting the smaller dish. It is a problem with the Slimline because it is heavier and has a larger area so there will be a higher force from wind. I believe a pole mount is $100 unless there is no other available location.
They/you can look into non-penetrating roof mounts; post mounts or eave mounts; BUT your look angles will determine part of their needs. Do they have clear looks at the proper azimuth from just about ANY possible mount location scenario?
Bob,
They charge a $ 100 bucks for a pole mount ???
Kevin,
If a pole mount would work for them, why don't you do the pole yourself for them.
There is a lot of info about how to do them on the site and if you have questions feel free to ask ....
Once you have a location that is clear to the SW, plant the pole (use cement) and then call D* out to do the rest.
IF you would like to dig a trench, the installer would appreciate it, they DO charge to bury lines.
Jimbo
Jimbo, I no longer have my work order (my AT-9 was installed two years ago) but recall that as being the price shown under optional items (I didn't need it).
Kevin, if you install it yourself, you will need a 2 in. OD pole which isn't all that easy to find. A fencing company would be a likely source.
Bob,
Kevin,
Jimbo
Or to the southeast, depending upon what part of the country the OP is in.
Tivo R10
R10 Activation- Phone Line Needed?
