"Move" Question
volinsc
4
Sc
I'm a long time lurker first post. I just "moved" from Charlotte, NC DMA to Greenville, SC DMA. It appears channels are on the same sat and transponder but I get an error screen that says something to the effect of local channels not available. It flashes complete signal loss then goes to that screen. Is there anyting I need to change in the set up? I thought it should just work from what I've read here.
Thanks for the help.
I am on EA. I'll move to Columbia area since those work in HD. Thanks for helping.
well otherwise go into the menu
(menu 6-1-1) and see what the signal is on the transponder I posted above (61.5 TP1)
OK did some more looking
The issue might be your actual location. You mention Charlotte so looking at the spotbeam maps on TP1 spotbeam is Richmond VA, Raleigh, and Greenville NC
On TP1 but a different spotbeam (coverage area) is Greenville, SC Chattanooga, Atlanta and Knoxville
Thats how spotbeams work. They can reuse the same transponder but in a different area.
so it may show signal on Tp1 but you're probably picking up the 1st batch above
Ok another question for you. I'm about to cancel E and switch to D and will want to do the same move. Will Greenville be available for me on D?
I do not know as I dont have maps for those...but I would hazard a guess and say probably not if you are in Charlotte
Buying a used 722k
No Video on Any Dish HD Channel
