Multiple LNBF & Recievers
The LNB's need to be a dual to run 2 receivers efficiently
If you get a motor, only one reciever can control it. The other receiver can see the same satellite as what satellite the main one is on.
Whatever I do, I normally hire someone to do the technical work.
If I buy a motor, I can have it set that with a push of the button on my remote, it will turn from one satellite to another? So it isn't like a rotor on a TV antena that are not preset for a specific direction?
A motor is automatic once you set it up. Each satellite you program where to stop the motor and when you change channels, if it si on a different satellite, the motor moves to the correct spot and stops.
Works pretty slick :D
(and it is hooked in series between the LNB and receiver so no extra wires needed)
2.4 loader key file question
Witch switch do you recommend
