MySQL Issues
isaacmorseMI
4,734
Southwest Michigan
So I have this instance of MySQL that I forgot the password to. I uninstall it and delete the file folder. When I try to install a new instance it gets to the apply security settings thing and then gives me the error that it can't connect to the database. It also says with that error that if you have just uninstalled an instance of MySQL that the previous file folder does not automatically remove itself and that you need to remove it. Then all of the methods I've found to reset the password don't work. I'm basically stuck... Any MySQL gurus out there?
Regedit. You'll need to find out what keys or users.
Ok. I found MySQL in Regedit. What do I need to do now?
Ok, you should now be able to set a new password, AFAIK.
You can call him Sir Jonathan..
Anyone has the new GRE PSR800???
