n00b tech questions
SFroehlich
I'm in the position of coming up to speed on Direc TV for some research I'm doing. As always clarity is a little hard to come by, but I bet some of you guys have answers to these questions. Consider this a newbie question - so links to answers will be fine.
1: Hughes / DirecTV DSS vs. MPEG-2 and the transition to MPEG-4/H.264
OK, so I get the fact that DirecTV started a little too quickly to be MPEG-2 compliant, but are the DirecTV "MPEG-4" broadcasts standard H.264 streams or do they retain proprietary elements?
2: DirecTV's two new satellites are using DVB-S2?
I know DirecTV has its own 8PSK modulation standard that uses a different FEC scheme (Trubo instead of LDPC?) from DVB-S2, but Wikipedia says that the new SPACEWAY satellites that they're going to use to transmit local HDTV broadcasts will be using DVB-S2? Is this right or is it the DirecTV propprietary 8PSK "standard"?
http://en.wikipedia.org/wiki/Directv
3: Listing of DirecTV Set-top Boxes?
Is there an easy place to find them listed with their specs?
If those are "noob" questions, I must be an embryo....lol. But I am sure someone where will know the answers.....Take care!
Try the search funtion at the top of the page, that way you can find the quotes that pertain to what you are looking for.
No national HD channels in dc area?
NBA League Pass in HD
