Need help with a dish rescue
caddata
333
Jacksonville, FL
Near my home, an old Caterpillar dealership is being demolished to make way for a new Lowe's Home Improvement Center. Perched atop one of the buildings is what appears to be 1.5M or 2M offset transmit/receive dish with the electronics removed. It is calling out to be rescued from a horrific future of destruction. Should I approach the destruction crew superintendent to save it from it's fate? I'm open for suggestions on how to approach him to save it. I won't be able to sleep knowing they killed an dish that just wanted to continue on looking into space and reflecting programming into my receiver.
CharredPC
606
Lakebay, WA
My advice is to simply ask.
No harm in trying, and I doubt the guys down there would care.
And personally I couldn't sleep at night knowing I hadn't done anyting to aquire an about-to-be-scrapped 1.2+ meter dish :O
drhydro
1,572
and ya know, offering the foreman a 6 pack of his fav. beverage would probably help......
Tron
6,599
35
Metro New Orleans, LA
I'm looking for opportunities just such as this right now. I live in a large metro area (New Orleans) and there are plenty of older buildings always being demolished. I'm sure I'm missing opportunities on all of those roofs for dishes.
I'm sure they wouldn't care at all if you got it. You're likely to get an NPRM (Non-Penetrating Roof Mount) in the bargain, which are VERY useful for mounting larger dishes on a flat roof! Most such mounts have a 2 3/8" pole bolted to a frame of some sort. You use cinder blocks to weigh the frame down to the roof, then you make adjustments to the pole and supports to level it. I have two such supports on my shed roof, and they're wonderful!
rkrenicki
976
For a dish that big, its more likely to be a 3" or even 4" mast.. much like the 1.2 I have at the house.... 3 inches
ken2400
1,309
144
Central NY State
Start off with asking. If that does not work start showing $$$ and go up by $10s
Good luck.
P.S. Make sure they know if they bent it the deal is over! Get some bi-nocks out and make sure it is not bent to begin with.
18" DSS dish and LNBF work for FTA?
Did you do anything on Field Day??
