Hi Mike, I picked up the Shack amp yesterday. It only has a max. output of 10 DB so I feel good about that. The Mgr. tried to talk me into a 30 DB gain amp, but I think that would be overkill in this situation. Of course I can always bring this amp back if it does not meet expectations. This is the same line amp I had 20 yrs. ago in CT. It had to be replaced annually, but it worked great. The Shack sells a 2 yr. warranty for $10 & I will go back & buy it if the amp works out. I installed two 25' cables the other day when I took the ant. & pole down for maint. and height adj. on the UHF ant. Now I can reach the UHF ant. w/out going on the roof. My pole goes into the ground & clamps to the house. I simply loosen the 4 bracket nuts and I can turn the whole thing for fine tuning.
I used the longer cables as they are from cable with nice ends. Today I will shorten them, hook up to the combiner, and then to the main attic cable. The only thing I don't like is the builder used RG-59 cables in the house & I have no access to where the TV is to run an RG-6 cable. After I do this I'll recheck the sig. on all the dig. chs. At that point if I'm still getting 2 weaker sigs. I will install the line amp and recheck the new sig. readings.
I'll let you know what the sigs. are when I'm done.
Dan
Dan,
You are going the same road as I would have. That 10db RS amp ought to work just fine, and getting the extended warranty sounds like a winner to me. Best part is that you can get it repalced locally, if need be.
As to the RG-59, unless you have LONG runs of it, that should not be a problem, either. Although most RG-6 is better for most applications, its not THAT much better that I would tear open walls or something to use it.
Hopefully, you have got things in hand now and as soon as you get a chance to put it all together, I feel very sure your setup will work just fine for you.
Was looking at my setup yesterday and am going to have to add 2 more sets to my antenna in near future for HDTVs I am putting in the home. I picked up a preamp that will feed up to 4 sets (since will only be using 3, will terminate the 4th feed), each at 8 db gain. That should be more than ample to make up for the 3.5 db loss of signal associated with each splitter and the additional cables I will be adding into the circuits. After I add the RG-6 to the circuits, insert the preamp into the circuit, all the locations should be just fine, no reason to get a 500db gain preamp.
Let me know how you fare!
-Mike
