Ok I am half installed. My box showed up at 3pm so I only had an hour and a half to play with it before it got dark. I was able to mount the Dish however I did not adjust any settings on the Dish.
Hopefully someone can tell me what my settings should be for my zip code 06111 I need the settings that need to be set on the motor as well as on the Dish.
I did fool around with he motor a little bit moving the dish left and right.
I know I will need to set it back to zero once I have light tommorow and set things up correctly.
I do think that I will need to move the dish in the spring so I can see more of the arc this dish is located to the right and slightly behind my superdish, so I know if the dish moves to the left I will not be able to see satellites like 61.5 but I can fix that later on.
