Only receiving 10 on 32 transponders post installation
Hi All,
Just wanted to drop you a line to say things are working now and a BIG thanks for your help - your advice and information was invaluable.
I had to increase the elevation from 32.5 to 36 or 37, keep the tilt at 61 and point the azimuth at roughly the same place where dishpointer told me to point it. However, I was still seeing zeros initially across the board but then, after recycling the power supply, suddenly numbers started appearing for all transponders and after a few degree tweaks for the azimuth, I now have signals in the 95+ range and a lot of 100s.
Thanks again!
Reactions: Jimbo and raoul5788
Your elevation should be 32.5°. I suspect you were using the wrong indicator for your elevation.
Moving to new home - installation questions - existing dish
C61k problems
