OTA pipe extension
AZ.
11,046
24,597
crazy
Got rid of Direct TV. Putting up a OTA antenna. Want to use the direct mount, looking to add 2' or 3' extension to gain some height....Any suggestions?
Well, I found this. Not specifically made as an antenna extension but might be able to make it work?
Reactions: AZ.
I see the site I posted previously expects you to order them in multiples of four. :oops:
Here is a site with a 4ft x 2" extension that allows just a single unit to be ordered.
Reactions: AZ.
Im going to give it a try! Thank you
Sorry, I think the DTV mount is simply not fit for purpose. Probably weak in wind.
Is an antenna mount and extension pole really that much more expensive than your jury-rig? Jerry-rig?
The price difference may be cheap insurance against ending up buying both.
Reactions: Foxbat
It could be and issue if the antenna is very large but I have seen many people reuse dish poles for smaller antennas without issue. I guess size does matter... ;)
Yes its a very small antenna, Everything is coming in fine but my local NBC. Last scan came up with 58 channels. 4 bolts in the roof for the dish. Then the 2 kickers are also bolted in the roof.
If I dont get NBC I will not get Sunday Night Football. But I can get all the Sunday games now via OTA. Its already a success. Not even sure how much longer I will live in this location?
The transmitters(repeaters) are 29 miles away. The problem is the terrain, and the location of that NBC, is behind a nice size mountain.
Reactions: FTA4PA
If you haven't already done so try tilting your antenna up a little bit to take advantage of the 'knife edge effect.'
That helped us get signal with 2-edge reception behind a large hill at 42 and 57 miles from the transmitters. :)
Reactions: Mr Tony
I noticed that the Winegard VHF antenna at our vacation home didn't quite make 50 years of life. It's on top of a 48' Ham tower so getting it down to replace it will require a bucket truck.
I think the ice storms that hit northern Michigan in the late winter/early spring were the final straw. My siblings and I are discussing our options. At this point, VHF is less important for OTA than UHF and the Wineguard VHF antenna seems to be okay, but trying to find a preamp that would fit it makes it a moot point. I'd be inclined to replace it with a Televés UHF antenna.
Scaffolding?
I'll suggest that. But the base would need to be at least 12' and more like 16' to be safe. That's a lot of scaffolding.
The tower base is designed with hinge pins and it was brought down once before. It requires a guide rope be installed about halfway to two-thirds up the tower to help ease it back down. Or, we say "towers are so 2000-and-late" and saws-all the legs to drop it into the driveway. My sister is in favor of that solution. Certainly the cheapest…
Tropo DX TV reception in Carrollton, MO on 8/14 & 15/2025
LPTV stations file opposition to ATSC3
