Got rid of Direct TV. Putting up a OTA antenna. Want to use the direct mount, looking to add 2' or 3' extension to gain some height....Any suggestions?
That Direct pole is 2"....Just trying to get it over the peak of the home. Between trees and mountains it does ok. Just missing the NBC stations.
Im going to give it a try! Thank youI see the site I posted previously expects you to order them in multiples of four.
Here is a site with a 4ft x 2" extension that allows just a single unit to be ordered.
2" x 48" Extension for Fixed Pro Series 8ft Upright
2" x 48" Extension for Fixed Pro Series 8ft Upright With this 48” extension for 8ft fixed pro series uprights, you can make your uprights even taller to your satisfaction. Our 48&rd...www.eventsupply.com
Sorry, I think the DTV mount is simply not fit for purpose. Probably weak in wind.
Is an antenna mount and extension pole really that much more expensive than your jury-rig? Jerry-rig?
The price difference may be cheap insurance against ending up buying both.
Yes its a very small antenna, Everything is coming in fine but my local NBC. Last scan came up with 58 channels. 4 bolts in the roof for the dish. Then the 2 kickers are also bolted in the roof.It could be and issue if the antenna is very large but I have seen many people reuse dish poles for smaller antennas without issue. I guess size does matter...![]()
If I dont get NBC I will not get Sunday Night Football. But I can get all the Sunday games now via OTA. Its already a success. Not even sure how much longer I will live in this location?
The transmitters(repeaters) are 29 miles away. The problem is the terrain, and the location of that NBC, is behind a nice size mountain.
Conduit size 1 1/2? IMC, EMT, or Rigid?I used a 10 ft. by 1.25" (id), the (od) is 1.5"conduit cut it to 5 ft. and an adapter from Menards. Has been on my roof for 8 years without problems.
Deck Adapter | Commdeck
commdeck.com
I'll suggest that. But the base would need to be at least 12' and more like 16' to be safe. That's a lot of scaffolding.Scaffolding?
Conduit is sized by the room inside for the wire bundle. I used 1.25" EMT. when I purchased it was $11. About triple that now.Conduit size 1 1/2? IMC, EMT, or Rigid?
