OTA pixelation and dropouts
bgcarl
20
Marietta, GA
Two of my HR20-100s have nuisance pilxelations and dropouts. When viewing signal strength, readings jump from "not acquired" to 90% and alternate between receiver 1 and 2. I can correct the problem with a restart but problem recurs in a few days. All satellite channels are O.K. Two other HR-20s are fine. I converted to SWM a few weeks ago but don't know if that's a factor. Is this a known problem and is there a fix?
Appreciate any help.
Have you tried swapping dvrs to eliminate a cable issue? Also, have you checked all of your cables and connections?
BTW, senior moment - I meant to say TUNER 1 and TUNER 2 in original post. Cables are fine. Also, I think the main clue is that a restart always temporary corrects the condition but it returns after a few days. I'll try swapping receivers with known ones that behave properly today but may not know success for a few days as I just restarted both misbehaving receivers.
Thanks fro the suggestion.
Keep isolating and keep us updated so we can help.
Any external MultiSwitches ?
