Pay to aim?
bryanw20
272
43
I'm about a year into my h3 upgrade (aka contract)
Dish is about 3+ yrs old.
I'm getting lots of digital breakup on different channels.
I don't pay for the insurance option whatever it's called.
If I call for a tweak what's it going to cost?
dare2be
SatelliteGuys God
12,743
7,776
FL
Call for the tweak, ask for the protection plan (8.99), and the call should cost no more than $10, plus the cost of a few months of protection plan or a cancellation fee of ($35?)
Reactions: TheKrell
bryanw20
272
43
Thanks; did some online research; looks like it's $8.99/mo $30 if removed <6 months
$95 fee w/o protect.
Just curious if being a long term (10+yrs) customer has any weight; or it is what it is.
Reactions: TheKrell
Tampa8
Supporting Founder - I'll stand up and say so
18,305
8,156
Tampa/Eastern Ct
My experience especially if you pay on time too, yes it might make a difference. Don't take a no answer from one CSR if they won't wave it try a couple others or ask for supervisor.
bryanw20
272
43
Thanks, and before I call/chat I may try to self adjust.
I found the signal strength in settings; but not sure what best combos to use.
I'm right in the center of the US, looks like I'm using 110, 119 & 129, so what tuner/transponder should I use?
just picking random tuner/transponders I see these strengths"
129 = 62
119 = 43
110 = 62
Ziptied
977
1,156
West coast
129 = 62
119 = 43
110 = 62
The majority of the time, adjusting the elevation a degree or 2 upwards will do the trick. Take note of the setting and give it a try.
Reactions: Tampa8 and bryanw20
Tampa8
18,305
8,156
Tampa/Eastern Ct
Not a big deal which one. 43 is low, 62 not bad. (For Western Arc which is what you have) You could pick one of the channels you see the problem on and see what that strength is. I would not be surprised if that 119 you see is a problem.
(Edit - I don't have a Hopper if you do I don't know if that scale reads the same as my VIP receivers)
Also be sure there is no obstruction or partial obstruction to the sky, check all connections and the condition of coax. It isn't usual to need it realigned, but certainly not unheard of. I live by the Ocean when I am in Florida, with higher than normal winds often, tropical storms with high winds etc... and have yet to ever need a realignment. But yours could have been right at the edge of being aligned and moved just a little, etc...
HipKat
21,635
44,249
Pekin, IL
Depending on which Transponder, but if's central US,. he should be in the 70's for 110 and 119
ChadT41
THE BEST THERE HAS EVER BEEN
Apr 20, 2014
11,083
4,515
Mesa, Az
Use Dishpointer.com with the satellite system 1000.2 Western Arc, type in your address... boom. You have your settings and even a line of site path to the satellites.
Reactions: bryanw20
Joey 4K and 4K Programming?
Bad equipment?
