PG time is wrong
owlbox
223
MA
The time on my set top box is always slow and therefore the PG always tunes to the channel something like 3 minutes after the program has started. Anyone else have this problem or know how to correct it? :confused:
Sean Mota
19,039
1,739
New York City
Mine always tune a few seconds before the show stars (using the PP). Did you try to reboot the box to see if there is a corruption in your PG. Also, which channel did this happen. I just recorded the three stooges on Cinema HD two days ago and it was fine. Also recorded Amazing Race and the Yankees game on CBS and the PP worked fine. I did not do any recording yesterday.
owlbox
223
MA
I don't remember seeing this behavior prior to updating the firmware. I have recently rebooted (a week ago) and the time is still wrong. I can try again tonight but that is a pain in the #$#% if I have to keep rebooting. Again I don't remember having this issue with the old code.
owlbox
223
MA
Does the STB get time corrections via the satellite or does it only set the time once when booting?
rollerfink
294
Detroit
I've never recorded anything on mine but I have noticed a couple of times that my box is a few minutes slow -- either that or the networks are colluding to start their shows a few minutes early.
owlbox
223
MA
Maybe the time is drifting but the box occassionaly gets an update so the time drifts in and out of calibration...?
cpdretired
801
461
Lemont, Il.
Actually the time is from bank around the corner from the uplink center.
DarrellP
I Think, therefore, I am.
4,298
Salem, OR
Some channels start early. I record Tom & Jerry at 11:30 daily for my daughter and it starts as much as 2 minutes early to 1 minute late, and it's not the box, it's the station.
Couch Patato
70
Lakewood, Co.
Yep, that's it! I've seen the time be right on & then 5 minutes later it's 3 minutes slow many times. One night I had hit the voom button that brings up the first page(Up top it shows the present time), about to go down to favorites & THEN, It actually went back three minutes & then flipped forward two minutes.:rolleyes:
owlbox
223
MA
Wilt, any ideas?
This last post from Couch makes it sound like it is Voom or the box as opposed to the station. Wilt, can you comment on this?
Sean Mota
19,039
1,739
New York City
I've got this from Wilt regarding this:
"I'll try to get both and explanation and it looked into.
Thanks for the input.
Wilt"
Scotty
154
I have a couple of these little battery operated clocks that pick up the time signal from some atomic clock out west, that broadcasts a radio signal that covers the entire us. They are alway right in sync with each other and I trust that they are receiving the atomic clock radio signal.
I have one on my coffee table, and voom is often showing a different time than the atomic clock does. Voom was over 3 minutes of synch. Voom was showing 3 minutes to the hour, while the atomic clock was showing on the hour, and the tv show for the next hour was starting so the tv station obviously agreed that it was on the hour mark. This is going to be painful when the dvr comes along. Why can't all clocks in all devices pick up this atomic clock radio signal and all be in synch?! They should have battery backups too, so they don't blink when the power goes out and comes back on.
I sure hope voom puts an atomic clock radio signal receiver in their DVR to keep synched to a good time source.
