I have just got Voom and am a happy subscriber. Need more HD though!
I currently have the stock Sensar directional antenna. This is used with the diplexer at both ends, thus using the receiver as the powersupply for the onboard antenna amplifier. As you can see by my location the local signals come from three different direction. The only station I really care to receive is "35". This trasmitter is on top of a hill that I can spot with with my naked eye. The FCC's website says it is 20miles LOS. Regardless of how I point the Sensar antenna I can not receive anything greater than 40 signal strength. For the time being I am pointed due north. This yelds a good (90+) signal on 38/42/27. Channel 5 has a signal strength of 20 when pointed in this direction. 42 and 35 are the only local stations that broadcast HD. The rest are just plain digital.
Voom is very happy to replace my OTA antenna. But they say that either I or the installer needs to recommend a specific model. This is where I would like your input, to make sure it gets done right the first time. Please keep in mind that the Sensar pointing directly at 35 does not receive a high enough signal, and I would like to receive atleast 35/38/42, but ideally all of them.
Thank you for your time and knowledge! (Ahead of time!)
