WANTED Polar mount
I got one, but you are 1600 miles away. Try to find an old 6ft mesh dish, and use the polar mount from that. I assume you want it for a KU dish?
Realize that when mounting an offset dish on a polar mount, you MUST tip the top of the dish forward, the same degrees as the dishes offset degrees. You can do that with added angle iron, but it should be built very strong, if you expect a lot of wind.
Reactions: comfortably_numb
I have an AJAK 180 HH that has been in storage for past 10 years. Was originally mounted on a hydroformed AMCI dish that I purchased in Reno, Nevada. Yes, true horizon to horizon and capable of lifting an elephant!
FREE to a good home.... Local Pick-up near Sacramento, CA. It is a beast and would require pallet shipping.
primestar31 is sending me a polar mount from a 6 foot Unimesh. I think it may be adaptable for the 1.2m
We shall see!
Anything's adaptable IF you are creative! Don't forget you'll need at least an 18" actuator motor, and some way to drive it. G-box or V-box. I think Rick sells one.
Plus extra angle iron or angle aluminum, and some fabricating skills.
to fit on what size OD pole?
Appears to be just shy of 2 1/2"
SOLD!! Amazon Fire TV Stick 4K Max Brand New Sealed
