Pro Bowl on Fox looks upconverted 16:9
LASooner
LASooner
462
22
It was in HD, but the Shockwave generated by Adrian Peterson was disrupting the equipment.
P
primetimeguy
1,003
39
St. Paul, MN
I would say the same thing to you about Fox. They are both good, but I think Fox does it better. As long as it looks good I don't care.
All FOX stations put out the same signal so same multi-casting is the same across the country, unlike CBS which varies by station. Some local markets look like garbage but the unmolested ones are unmatched. There is a pretty good consensus on most web forums that CBS is tops in PQ and when it comes to the NFL, FOX is a good notch down. Now maybe your display isn't large enough or you sit to far away and that could explain things.
But I will agree with you about AP.
osu1991
osu1991
9,905
2,341
Broken Arrow, Oklahoma
I don't know the last time I looked 70 inches was considered pretty big, and just like CBS all Fox stations get the same signal but not all Fox stations multicast ours doesn't and if 70 isn't big enough I can go up to 103 with the projector, or down to 60 with the Sony but like I tell everyone else it doesn't matter what anyone says as long as it looks good to you.
I
i4tas
791
4
Northern USA
has any network ever done live HD out of Hawaii?
I can't remember if ESPN did it for college basketball or football...
digiblur
digiblur
14,190
4
Louisiana
Negative. All Fox stations do not multicast. I know one nearby that runs at 17mbps.
P
primetimeguy
1,003
39
St. Paul, MN
Correct me if I'm wrong, but I think all FOX stations use the same splicer system and the signal coming to each affiliate already has a chunk cut out for the multi-cast channel. Now the site may not add in their multi-casting but the PQ is just the same as if they were.
Here is a link discussing the issue....
Will Fox kill the null packet stream for Super Bowl XLII ? - AVS Forum
And from FOXeng specifically "And no, I don't expect anymore bandwidth than the 16 max "
Jim5506
Jim5506
7,615
2,452
Lubbock, Texas
Since FOX is 720p60 they do not need the whole 6MHz to transmit their HD signal, many stations use it for a weather channel.
P
primetimeguy
1,003
39
St. Paul, MN
There's way more info in a 720p60 broadcast than can fit in a 6Mhz channel, hence compression. Using the entire bandwidth of the channel reduces the amount of compression.
who_the
who_the
342
San Francisco, Calif.
There are no full-size HD trucks in Hawaii to handle sports broadcasts. ESPN contracted with a smaller company (and flew in a bunch of equipment) to broadcast the 2007 Hula Bowl in HD. Very much of a makeshift operation though. I think ESPN was trying to show up Fox this year by broadcasting their Pro Bowl coverage (NFL Live, SportsCenter spots, etc.) in HD, especially since they knew the game would be in 16:9 SD.
Hula Bowl to be high-definition broadcast - Pacific Business News (Honolulu):
digiblur
digiblur
14,190
4
Louisiana
Here's KARD running at 17.6. This is what they are putting out now what they are receiving is a different story.
T
thedamaja
444
South Bend, IN
My local Fox also looks great at 100" they have no subchannels
On the other hand CBS has constant macroblocking with sporting events. I cringe every year when March Madness rolls around. They have murdered the first couple rounds for the last 2 years.
Similar threads
M
Replies
6
Views
2K
Jim5506
Jim5506
fmj77
Replies
7
Views
1K
sam_gordon
S
ralfyguy
Replies
16
Views
2K
dfergie
dfergie
C
Replies
20
Views
3K
gdarwin
gdarwin
