Quality Coax
Most any new coax you buy is 3ghz. Old coax usually works just fine. I have some belden from the 80's I still use. just because it is not tested to 3ghz does not mean it can't carry it. To me a lot of the new cable "appears" to be of a lessor quality then the old.
I haven't bought any RG-6 for a long time. But like what the Mack stated, it's probably all 3 gig rated now.
The last time I bought some, the center conductor was pure copper. (Belden) which I personally prefer. But copper clad aluminum (CCA) is fine also.
Just to make sure I understand everything correctly.
Solid Copper or Copper Clad Steel:
Doesn't matter.
Dual shield or Quad shield:
Doesn't matter.
3Ghz:
Any coax cable probably supports it.
It sounds like the same cheap coax the cable company uses, is that right?
722k not seeing external drive
54.0 remote won't power up Onkyo AVR
