Questions about Reception
abukamoon
9
I have a couple of questions and I hope someone can answer them.
1. I noticed recently that some channels had moved. I searched them out and found a few that had no picture but the sound was there. I did new scans several times but still no picture. I am wondering if this is on my end - could my dish have been moved? Or, is the problem with Galaxy 19?
2. When moving between channels, a blue panel pops up for a few seconds announcing the name of the channel. About half of these are incorrect. Again, is this something that Galaxy 19 needs to correct? For example, one channel says "ALKAWTHAR" but the channel is actually "I FILM ENGLISH", or the panel says "YEMEN" and the station is actually "PALESTINE".
Thanks in advance,
abukamoon
What kind of STB/receiver are you using? Check your cable and connections. Check your STB. I wouldn't start fiddling with the dish itself just yet.
Might have to re-scan some transponders. Channels sometimes change around on G19Ku. Also as mentioned above, some channels have gone to MP4 (H264) video compression that require a newer receiver to play video. Might be time for an upgrade. There's a unit that plays H265 video compression (backwards compatable) supplied by members on this forum, check the receiver section.
Reactions: comfortably_numb
Thanks for the input. I have done several scans. Is there a way to re-scan particular transponders? Can you suggest a unit that would be compatible? Most of the channels come in very well on my Lexium. thanks again.
Try KE4EST, he might have a supply. :) I have the HD-RE, the previous model and it would do what you need, but I think those are likely all gone.
Another option is a PCI-card or USB receiver, but those are much more complex to deal with because then you are dealing with various softwares to read the signals.
Not sure on your Lexion for scanning particular transponders, maybe try "satellite scan" and see if there is an option to scan particular TPs. If you already have the transponders in the list there would not be a need to add anything or blind-scan.
Thanks for the info but it's too technical for me. I have been watching FTA for 6 years but I don't really understand all of the electronics. The system was set up for me by a guy who used to install Dish TV. Thanks.
I got my answer today. I spoke to the man who owns Ricks Satellite and he told me that several stations had recently gone to high definition broadcasting and that when I re-scanned, the Lexium 7000 didn't recognize the HD programming.
The only thing to do is get a new receiver if the channels you want went to HD. There is about 5 HD channels on 97w now.
Sent from my P00A using the SatelliteGuys app!
