Added a third U-bolt today. Now the dish is almost 100% locked down and won't move left or right
I'm becoming a regular fixture down at the hardware store
Hello Comfortably
Where did you buy the non-penetrating mount?
Can this mount be use like on top of my cover patio?
Please let me know.
Regards.
Tunder
Thanks for this information, My patio has a little pitch but not that bad, just wanted to make sure it does not move with the wind, I had to get rid of my 1.2 dish because the wife needed the area to plant tomatoes,I got it on Amazon; its the Perfectvision NPR6B. I got 8 blocks from Menards to load it down. Its great for a patio; I have 2 on mine
Can't say how well it would work on TOP of a patio; its heavy. But sits well on concrete.
Thanks for this information, My patio has a little pitch but not that bad, just wanted to make sure it does not move with the wind, I had to get rid of my 1.2 dish because the wife needed the area to plant tomatoes,, so my only alternative is to set one smaller dish on top of my patio.
Regards.
Tunder
@tinder For your 1.2m motorized project, I suggest a NPRM with the larger post. 2 3/8 post will work better with the hh motor.
Here is an example:
Thanks Guys, these are the dishes I am looking at:
1m Technomate Mesh Hi-Gain Satellite Dish & Pole Mount Fittings 105cm
www.systemsat.co.uk/mesh-satellite-dishes/1-1m-mix-digital-mesh-satellite-dish-with-0-1db-lnb-110cm.html
They claim they can ship them to USA and they are willing to put extra protection for the dish, of course for an extra charge.
Let see what the total price is.
Regards.
Tunder
Thank you guys, I didn't know that the 90 cm dish was only 12 pounds, this is perfect for my patio and away from my wife's view,, lol, Well if the mesh dishes from EU are to pricey with shipment I will get me this 90 cm, what is the best standard LNB out these days?
Let me know.
Regards.
Tunder
Regards.
Tunder
The real (and surely cheaper) solution is to order the appropriate bolts from said hardware store. Most have overnight access to fastener distributors if not sooner.Now you need to go back to the hardware store and buy a tap and die set and get rid of all washers
Sure will, I kind of having second thoughts, they do not have packing information on how well the dishes are packed, if the dish is damaged I don't think they will replace it and would a pain to return it.Please report back when you get final prices -
Let me ask you this, your 90cm dish which satellite is the farthest you can scan.
Let me know.
Regards.
Tunder
Hello cnMoved the reversible pole on the non-penetrating mount to the 2" side, then installed the mount and dish. It's a bit unwieldy doing it alone, but I finally got it on there.
View attachment 136154 View attachment 136155 View attachment 136156 View attachment 136157 View attachment 136158 View attachment 136159
Hello CN
What is the size of the cement blocks you are using on the dish mounts?
Please let me know.
Regards.
Chewie
I always remember you that way.Chewie
