Remote
If it's with an HR24 or newer, they practically set themselves up. Which receiver/dvr do you have?
I'm guessing one is set to ir and the other to rf. Go into the menu of the dvr and change whichever it is set at.
I already have one remote that works I am using the other remote for the tv upstairs which isn't working if I change the Ir to RF the one remote that is working the other one may not work.Thanks for your help
the remote that is NOT working:
move the switch to D* mode (if its not already)
open the door by the access card
get the last 6 digits of the number on the sticker above/below the access card
press mute+select on remote, light at top will flash twice after about 2s
press 9-6-1, channel up, light will flash twice again
put in the 6 digit number you got from the sticker
new remote should be programmed now
if that fails, use the working remote to go into settings > remote > advanced > ir/rf > choose rf from the drop down > program new remote from on screen instructions.
Reactions: Jimbo
Can this info be somewhere in a D* Sticky so people can find it, we use to have a Sticky for stuff like that.
Network light blinking yellow on DirecTV Deca adapter
AT&T phasing out STB and Satellites by 2020?
